-   -   Water heater hot outlet union leaking (http://www.diychatroom.com/f7/water-heater-hot-outlet-union-leaking-15407/)
dog193 01-09-2008 09:58 PM
Outlet has a 3/4 nipple screwed in, then a 3/4 metal (appears to be galvanized) union going into another 3/4 nipple soldered to copper piper.
Water started leaking from the union today. Tonight I disconnected, cleaned and used teflon tape on the threads of the union but it still leaks after two attempts.
Other than replacing the union are there any other suggestions?
Should I be using pipe dope instead of teflon tape?
Thanks in advance,
Jay in Illinois
tubguy 01-09-2008 10:46 PM
Exactly where is the union leaking. Where the two halves go together or on either side?
dog193 01-09-2008 10:56 PM
It's leaking around where the big nut joins the two pieces together, water is coming up through the threads.
Bondo 01-10-2008 06:14 AM
Ayuh,......
Those fittings seal against their Faces,... No need for Tape or Sealant.....
My 1st Guess is,... Your's has corroded or rusted,+ Probably needs to be Replaced.....
tubguy 01-10-2008 09:07 AM
It is odd that it started leaking out of the blue. You could try using pipe dope on the threads and use 2 big wrenches to tighten things back up. Hope it works.
Mike
