Old 09-19-2012, 04:42 PM   #16
Water heater hot outlet leaking
Ok, just got word and they say 3-6" for the dip tube.
RodneyBR is offline   Reply With Quote
Old 09-19-2012, 06:55 PM   #17
The longer one was for an outlet that went in the top of the tank, not the side.
Old 09-19-2012, 07:41 PM   #18
Another job finished. Thx everyone
Old 09-19-2012, 07:53 PM   #19
A "Handy Husband"
rjniles's Avatar
That water heater (made for mobile homes) does not use a dip tube. The cold water is plumbed to the bottom of the tank.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 09-19-2012, 08:13 PM   #20
Really, because it works fine. Rheem told me what part and to cut it at 6".
Old 09-19-2012, 09:44 PM   #21
Doing it myself
Alan's Avatar
You don't need one because the cold water is plumbed into the bottom of the tank.
Journeyman Plumber
Old 09-20-2012, 05:02 AM   #22
A "Handy Husband"
rjniles's Avatar
Yes really, notwithstanding you do not have a dip tube on the hot side even with top connected supplies.
Tags
leak, rheem, water heater
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 10:17 AM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 04:41 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
