#1 |
Water heater hot outlet leaking
I have a Rheem Ruud PV50, 16 year old water heater and it recently started to leak around the hot outlet. Is there an easy way to fix this? I'm thinking heat it up with a torch and solder it.
Pics below. ![]()
#2 |
Heat and water make steam and steam doesn't solder well. Replace the fitting before catastrophic failure. Those 16 years won't set any records for service but in general that's a good life as water heaters go.
| The Following User Says Thank You to Fairview For This Useful Post: | Alan (09-17-2012) |
#3 |
Time to start thinking about replacing it. Tank would have to be empty and dry around that fitting to try and solder it back up.
#4 |
You have a corrosion problem where 2 different metals and water touch. You are supposed to have a dielectric fitting at the cold and hot connectors, where copper/bronze and galvanized iron connect, or this problem will develop again in the future.
#5 |
That fitting is about to blow! No joke.
#6 |
Thanks for the comment folks
It's appreciated.So don't try and fix it, replace the fitting? Is this fitting readily available, like for example at Home Depot/Canadian Tire? Also, how would I replace it? I see that it screws into the copper pipe, but is the fitting soldered or screwed onto the tank? |
#7 |
http://www.amazon.com/Camco-10623-Di.../dp/B0006JLVEO
Any Lowes Home Depot, hardware store will have one. Do not be surprized if it just breaks off when trying to remove it. I also would pick up a Shark Bite coupling the size of that copper pipe. You have to shut the heater off, shut the water going to it, drain water out at the bottom of the tank. Once it drained you cut the copper pipe and unscrew the copper elbow, then the nipple. I'd apply pipe tape and pipe dope on the new nipple. Use the shark bite to reconnect the copper pipe. I know if it was mine since I'm doing half of the work to replace the whole tank anyway, and knowing in most cases no one has ever drain any water out of that tank like your suppot to evey year to get rid of sedamants and most likly will not drain, I'd just replace the whole tank. Is there a shut off valve in the incoming cold water line? There should have been a ball valve there. |
#8 |
replace it with a new dielectric nipple or a brass nipple.
#9 |
Doing it myself
It looks like a GALVANIZED nipple to me anyway. You can't solder it.
Normal tank life on water heaters is around 10-15 years. I think you're reaching the end.
Journeyman Plumber |
#10 |
Master Plumber
Water heater hot outlet leaking [QUOTE=Alan;1012054]It looks like a GALVANIZED nipple to me anyway. You can't solder it.![]() Normal tank life on water heaters is around 10-15 years. ![]() I think you're reaching the end.
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#11 |
Average Joe/ex-Navy IC3
Wow 16 years. Call yourself lucky, and get a new one.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#12 |
Believe it or not, my parents still have an old Rheem 40 Gallon water tank heater, installed 35 years ago (when I was a kid and it was a new house) still in pristine shape and working just fine, with no corrosion (the house still have lead pipes), no maintenance has ever been done to it (other that an annual flush of sediments). It has to be the water, IMO.
#13 |
Ok, got all the parts at Home Depot and I'm on my way to doing the job. Although, I have a question as to how long the dip tube should be? Because the old one didn't have one to measure the length or it corroded off. Pics below...
New Dip Tube and Nipple: ![]() Old Nipple:
#14 |
Rheem just got back to me on the dip tube length. They said anywhere from 28-30", longer for large volumes of water.
| Tags |
leak, rheem, water heater ![]() |
| Display Modes | |
| Low hot water pressure | crebive | Plumbing | 38 | 02-26-2013 01:26 AM |
| Tankless Water Heater | a7ecorsair | Plumbing | 56 | 05-04-2012 10:17 AM |
| rumbling pipes and leaking pressure relief valve | rogerwright | Plumbing | 21 | 04-14-2012 03:35 PM |
| Water Heater Constantly Failing/Replaced | DroidGuard12 | HVAC | 6 | 04-11-2012 04:41 PM |
| A blocked water line causing water to loose heat? | Snav | Plumbing | 6 | 05-07-2010 03:18 PM |
