Old 07-13-2010, 08:10 PM   #1
water heater gone bad?
For the past few days my wife and I noticed a lack of hot water. Today I was giving my kids a bath and had almost no hot water. I went under the crawl space to check on it, nothing was leaking and the top of the unit felt hot. The drain (?) on the bottom of it did not drain hot water as I have seen before. What do I do?
1. Believe that the heat strips have burned out?
2. Just go ahead and replace it, I have no clue how old the heat is.
Thanks.
Toolmaster is offline   Reply With Quote
Old 07-14-2010, 07:36 AM   #2
The year of manufacture is in the model #, unless it is very old.
If the tank has not been drained/flushed for a long time, the silt may be built up above the drain. A coat hanger or such can usually loosen the goop, but careful, that is hot water. If you only get hot water for a few minutes, sounds like the dip tube has deteriorated. It is under the cold inlet and is supposed to direct cold wat to the bottom while hot is drawn from the top. If the tube is shot, cold mixes directly with hot at the top diluting it. Dip tubes are not too hard to change(available at homes stores, plumbing supply), but if the tank is older than, say, 10 yrs I would not bother. Get a new tank.
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
