Water Heater Goes Out Every Week Or So - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2013, 01:11 PM   #16
Rewards Points: 91
its working!
Guys, just wanted to report back - my old water heater now seems fine. 3 weeks without a re-light!!! Normally it'd go out every 2-4 days!
So, worth me stating the fix, should it help someone else - really a lesson in trying the easiest thing first....
So, as previously reported, the new thermocouple didn't improve things. I then had a blockage in my main plumbing line, so had a plumber out. While he was there, I asked if he could take a look at the water heater. I showed him where I'd replaced the thermocouple, he said everything looked good, and if it wasn't working at that point, i probably need a new water heater. He also thought it was unlikely that the missing viewing glass was the problem, but he said he had some aluminum tape, he could stick a bit over the hole and see if it helped. It couldn't hurt and would only take a few seconds to do. So, he did that, and it's not gone out since!
So, as unlikely as it seemed, i guess that piece of glass not being there was the critical element for me. Very happy now - think i got a bit lucky there, as i was already researching new water heaters! That $80 call out for the main line blockage has saved me some money!!! thanks for all the advice!
cheers,
Matt
mmhendrie is offline   Reply With Quote
The Following 2 Users Say Thank You to mmhendrie For This Useful Post:
FClef (07-08-2013), jmon (07-08-2013)
Old 07-08-2013, 11:57 PM   #17
FClef's Avatar
Rewards Points: 160
Glad to hear everything worked out. Draft can be a funny thing and can cause all sorts of problems. Glad a $0.03 strip of tape fixed it.
FClef is offline   Reply With Quote
Water heater issues?!? NJdan Plumbing 1 06-04-2015 07:42 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
