Water Heater Gas Adjustment - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2012, 09:34 PM   #1
water heater gas adjustment
mywater heater will not light i replaced the thermostat how do i get it to light the igniter is working
chirpper1 is offline   Reply With Quote
Old 03-16-2012, 09:37 PM   #2
i still need to know how to adjust ths flow of gas
Old 03-16-2012, 10:36 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
There are no adjustments you can make on a water heater.
If the pilot isn't lighting do you have gas pressure to the valve?
Just back from a service call for almost the same concern. Regulator at the meter went out. Wasn't you was it?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-16-2012, 11:08 PM   #4
Rewards Points: 1,418
Don't forget that on most heaters you must turn one knob to "pilot" and hold down a button or lever while you press the igniter or hold a match to the pilot nozzle.
After the pilot light catches, keep holding the button for about 60 seconds.
If the gas piping had been disassembled for any length of time, air could have gotten in. It is necessary to bleed out the air so gas gets to the pilot nozzle before the pilot light will catch. It may be necessary to hold the button down for several minutes to let all of the air out the pilot nozzle. Then wait five minutes to let any gas that also came out dissipate, avoiding a little "pop" when you stick the lighted match inside.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
