Water Heater & Furnace Platform - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-14-2010, 06:47 PM   #1
water heater & furnace platform
I am considering locating water heater and furnace together in the garage. I would need an 18" platform for both. I've seen platforms large enough for only a water heater, but is there one that can fit both furnace and water heater or would I have to build my own? Also, I would need to level it since it will sit on sloped ground. I think I might be better off building one, but just want to see what ideas other people may have. If I build one, it would be out of wood. is there any special criterias I have to follow?
acerunner is offline   Reply With Quote
Old 09-14-2010, 07:35 PM   #2
HVAC / Plumbing
Should be ok. but, check the clearences to combustible material on the installation instructions
kenmac is offline   Reply With Quote
Old 09-14-2010, 08:25 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 354
use treated lumber when in contact with concrete.
adjust your stud lenghts to compensate for floor slope.
sheet sides and top with plywood for shear strength.
when putting appliances in garages you usually need to add balisters in front so you don't hit them with a car.
Wter htrs weigh a lot so build it strong
Do I need a gas meter/service upgrade? DIY water heater project please help. Philip_Soldat Plumbing 17 11-16-2009 06:36 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 04:32 AM
