Water Heater. Flame Doesn't Stay Lit - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2014, 10:42 AM   #1
Rewards Points: 105
Water heater. Flame doesn't stay lit
Richmond hot water heater. Been doing this for awhile. When the initial start up to heat the water heater, blower goes on, then there is a click to start the flame. You can hear the flame. Then the flame goes out and it repeats to start up. Does this a number of times. Thanks for the help.
gmbwrenchn is offline   Reply With Quote
Old 01-18-2014, 11:54 AM   #2
Rewards Points: 1,958
Whats the model of the heater?
Old 01-18-2014, 12:08 PM   #3
Rewards Points: 294
Some of those have sensors that go bad and need to be replaced. As mentioned above, really need model number to go any further. Thanks.
jmon is offline   Reply With Quote
Old 01-18-2014, 12:16 PM   #4
Rewards Points: 105
MODEL # 5VP40E-1 A
Old 01-18-2014, 03:36 PM   #5
Rewards Points: 105
Found this on another forum. I did this and it still happens
Since you are getting to the point of ignition then most likely it is failing to approve the ignition. If your pilot is of adequate size then take some sandpaper and clean off the flame rod that is next to the pilot. -- Ej (1/7/12)
The Following User Says Thank You to gmbwrenchn For This Useful Post:
TJN66 (01-26-2014)
Old 01-18-2014, 06:06 PM   #6
Rewards Points: 294
Check pressure switch for moisture, remove and shake it, if water comes out, replace it.
Check vacuum hoses for cracks and loose connections.
Check pvc vent for obstructions, it may be building up condensation.
Check fan blades on blower for caked on dust.
These suggestions came from your owners manual in the troubleshooting section. If still no luck, call the manufactuer for further information. Part(s) may be covered under the waranty, and may save you some money. Sorry I couldn't be of more help to you. Let's see what others recommend.
Old 01-19-2014, 10:26 AM   #7
Rewards Points: 105
Well looks like it's working fine now. Who knows. Thanks for the additional things to keep in mind in case it acts up.
jmon (01-19-2014)
Old 01-19-2014, 10:32 AM   #8
Rewards Points: 294
Poof! It's like magic. Glad everything's working now. Keep an eye it.
Water heater issues?!? NJdan Plumbing 1 06-04-2015 07:42 PM
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 03:41 PM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 09:12 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
