Water Heater At End Of Cold Trunk? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2011, 03:10 PM   #1
Maryland
Water Heater at end of cold trunk?
Running 3/4" CPVC trunk for cold water. I'm connected to the line coming from the water meter and then I used 3/4" x 3/4" x 1/2" tees to each of my fixtures (shower, toilet, two faucets in vanity). After the fixtures, I turn down 90 degrees to my water heater. Are there any issues with this configuration as opposed to tee'ing off the 3/4" main and running individual 3/4" trunks for the water heater/fixtures? In other words, will it matter that the water heater is being supplied last in line instead of first? Will I have low hot water pressure if I'm running the cold water on say.. a vanity faucet or the toilet tank is filling?
Pittsville is offline   Reply With Quote
Old 05-24-2011, 07:04 PM   #2
Maryland
Any ideas?
Old 05-24-2011, 07:20 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 776
You'll should be OK if 3/4 is the proper size for your service
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
water heater relief valve dripping (with gauge readings) ziguan Plumbing 10 01-28-2011 10:12 AM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
