Water Heater Drain Valve Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2006, 08:13 AM   #1
Water heater drain valve leak
I just finished change my heating elements in my water heater. Now that I refilled the tank I have a leak in the drain valve. Could this be because of hooking the hose to the valve, causing some damage? Is there an easy solution for this? Thanks!
Fletcher33584 is offline   Reply With Quote
Old 02-28-2006, 09:36 AM   #2
Remodeler
MinConst's Avatar
If the leak is from the spigot this would mean the valve is not shutting off. Might be a piece of sediment. Try running water through it an it might clear itself. If the leak is around the outside of the handle tighten the nut around the valve stem a little. If the leak is where the valve connects to the tank you may have damed the tank. Without seeing this I can't say much more.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 02-28-2006, 06:14 PM   #3
I ran water through the valve and that made water leak faster. I'll have someone come out and repair it. Thanks for the help!
Old 02-28-2006, 07:07 PM   #4
jproffer's Avatar
Rewards Points: 718
If the water is leaking out of the spigot itself (where water is SUPPOSED to come out when the faucet is on) you can save the repair. The W/H isn't going to last forever anyway. Go to the hardware store and get a hose cap ($2 maybe) and put it on the spout of the spigot. If you ever need to drain it, just take it off.
BTW, this won't effect the safety of the W/H as this particular drain valve has nothing to do with the T & P valve anyway.
jproffer is offline   Reply With Quote
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Water heater leak? spydrtrbo Plumbing 1 06-29-2006 07:56 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
Hot water heater leak? chrisintroy Plumbing 3 02-27-2006 09:13 AM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 05:00 AM
