-   -   Water heater drain valve leak (http://www.diychatroom.com/f7/water-heater-drain-valve-leak-1946/)
Fletcher33584 02-28-2006 09:13 AM
I just finished change my heating elements in my water heater. Now that I refilled the tank I have a leak in the drain valve. Could this be because of hooking the hose to the valve, causing some damage? Is there an easy solution for this? Thanks!
MinConst 02-28-2006 10:36 AM
If the leak is from the spigot this would mean the valve is not shutting off. Might be a piece of sediment. Try running water through it an it might clear itself. If the leak is around the outside of the handle tighten the nut around the valve stem a little. If the leak is where the valve connects to the tank you may have damed the tank. Without seeing this I can't say much more.
Fletcher33584 02-28-2006 07:14 PM
I ran water through the valve and that made water leak faster. I'll have someone come out and repair it. Thanks for the help!
jproffer 02-28-2006 08:07 PM
If the water is leaking out of the spigot itself (where water is SUPPOSED to come out when the faucet is on) you can save the repair. The W/H isn't going to last forever anyway. Go to the hardware store and get a hose cap ($2 maybe) and put it on the spout of the spigot. If you ever need to drain it, just take it off.
BTW, this won't effect the safety of the W/H as this particular drain valve has nothing to do with the T & P valve anyway.
