Old 09-22-2010, 05:55 PM   #1
Bigmike33's Avatar
Water heater drain pan line
I have a 30 gall. water heater in a closet that sits underneath the a/c.(first floor condo) I need to run a 3/4" drain line somewhere. There is a Drain standpipe in the wall that the a/c condensate is tied in to. Can I tie my drain pan line into this same standpipe? If so, what kind of a fitting could I use to tap into the standpipe without cutting it and using a union?(maybe a saddle type connection?) Also would there need to be a check valve or something in the line in case this condensate line backed up?
This closet is on an outside wall. Would it be easier to just poke outside the wall with a piece of pipe?
Bigmike33 is offline   Reply With Quote
Old 09-22-2010, 09:29 PM   #2
HVAC / Plumbing
If this is the T&P line. It should not be tied into condensate line
kenmac is offline   Reply With Quote
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
Leak on gas heater water line? darsunt Plumbing 3 04-16-2008 04:57 PM
