Water Heater Drain Pan - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2013, 04:11 PM   #16
those pans are useless if a water heater breaks loose that little pan isnt going to do anything i am a licenced plumber by the way
zcs20027 is offline   Reply With Quote
Old 03-22-2013, 04:13 PM   #17
Can I get your email so I can ask you some plumbing questions?
miguel24932 is offline   Reply With Quote
Old 03-22-2013, 04:16 PM   #18
Always learning...
fetzer85's Avatar
Rewards Points: 262
It depends. My water heater went out last week and it was just dripping heavily - almost a steady stream. In that case a pan w/ drain pipe could direct the water away from something you don't want to get wet. Of course it won't help in all failure scenarios but I suppose some is better than none? By the way, I'm not a licensed plumber.
fetzer85 is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
How do I drain my water heater? HVAC_NW Plumbing 10 11-10-2010 03:15 PM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-27-2010 11:00 PM
Does code require floor drain for water heater? Quickdraw Plumbing 1 05-21-2009 06:29 AM
