Water Heater Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-23-2010, 11:32 AM   #1
jdr
Water heater drain
New house - builder built water heater closet with open drain hole in center and some slope in the slab. What is the best way to slope/seal cement and what kind of drain should be used? Do we need a drain pan?
jdr is offline   Reply With Quote
Old 10-23-2010, 11:58 PM   #2
Rewards Points: 1,418
Most city codes require a pan under the water heater. The pan outlet should be run to the outside or to a drain although this is often difficult for a water heater in the basement. In your case it is easy because there is a floor drain.
Since the floor is sloped, you should put shims under the legs or feet of the water heater so the water heater is precisely upright.
Old 10-24-2010, 05:14 PM   #3
Rewards Points: 150
Is this a gas heater?, if so there are special regs. that apply to them.
If all you have is a hole in the slab it sounds like some kind of jerry rig!
Is this heater located in the living area?, local codes probably require a drain pain.
If you are in a earthquake zone, (Calif.), you need the heater succured to the wall
braindead is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
How do I drain my water heater? HVAC_NW Plumbing 10 11-10-2010 04:15 PM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-28-2010 12:00 AM
Does code require floor drain for water heater? Quickdraw Plumbing 1 05-21-2009 07:29 AM
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
