Water Heater Discharging Water From Drain Cock. - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2010, 12:57 PM   #1
Water Heater discharging water from drain cock.
Hello all.
I have a water heater about 3 or 4 years old. I have a bucket under the drain cock because of a small leak. Would fill this small bucket up in a bout a month. Very small leak. So I just left and emptied out the bucket once in while.
In the last week, this bucket is full and over flowing with water every day. I'm not losing any hot water. I can't tell when it happens, or if the water is hot originally when it comes out.
Should I replace the the drain cock, or could it be something else. And why could this be happening?
Thanks!
Rudy
Rudy68 is offline   Reply With Quote
Old 06-14-2010, 01:05 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
is it coming from the drain or the TPR valve?
If from the drain, one of two things would have to happen:
1. the drain is not sealing well
2. there is enough pressure building up that overcomes the valve.
If #1, you might consider replacing the valve
if #2, you may have a malfunctioning TPR along with something such as a malfunctioning thermostat.
so just to be sure: it is coming from the drain or the TPR tube?
and is this an electric heater or gas?
have you ever opened the TPR to be sure it is still functional?
Old 06-14-2010, 01:39 PM   #3
Hi Nap!
It's a gas water heater. And the water is coming from the drain. I haven't opened the TPR tube. Can I just open it with a bucket underneith, or do I need to prep something?
Thanks!
Old 06-14-2010, 01:50 PM   #4
nap
You talking to me?
nap's Avatar
the tpr is simply a pressure limiting valve. It is spring loaded and SHOULD simply re-close and seal when you release it.
Some of them do have a tendency to seep.
Electrical heaters have a lot more problem with t-stats than gas does but it is not impossible for a gas fired heater to have problems with the state. Have you noticed any increased water temp at any time?
Old 06-14-2010, 02:04 PM   #5
Originally Posted by Rudy68 View Post
Hi Nap!
Thanks!
There should be a little metal clip you can flip up, that should open the TPR valve. You might want to have a bucket under the pipe. The water will come out with some force, and should be pretty warm.
I had an older water heater in my old apartment, I had to play with the TPR to make it seat properly or else it would leak.
Also, is the leak coming from the drain valve, or from the drain valve valve fitting and dripping off the valve. If it is a Nylon shut off, it might be as simple as taking the old valve off and teflon taping the fitting.
McSweny1103 is offline   Reply With Quote
Old 06-14-2010, 02:23 PM   #6
Hi Guys!
There is no increase in water temp. It is coming from the drain and not around the fitting or anything.
Is it possible to replace the drain cock, and I should be good?
Thanks!
Rudy
Old 06-14-2010, 02:30 PM   #7
Yes, or you could attach a second shut off and just leave the maufactured shut off on
Old 06-14-2010, 04:58 PM   #8
DIY staff
Rewards Points: 7,174
If the drain cock is just dribbling --I'd suggest a screw on "bottle cap"---They are available wherever hoses are sold.---Changing the drain cock is a lot more work than screwing on a cap.
Old 06-14-2010, 05:15 PM   #9
nap
You talking to me?
nap's Avatar
Oh ya, especially on an older water heater.
I will say though that whenever I get a new water heater, I replace the OEM valve with a ball valve. It is much easier to flush a tank with a ball valve (allows full unrestricted flow through the valve) than whatever kind of valve it is that comes on them (can't remember what it is called at the moment)
Old 06-14-2010, 06:16 PM   #10
Thanks for the help. I think I'll replace the drain and see what happens!
Old 06-15-2010, 07:35 AM   #11
Rewards Points: 1,214
I agree this is the way to go without opening a hornets nest.
COLDIRON is offline   Reply With Quote
Old 06-15-2010, 08:31 AM   #12
I pulled off a drain valve on a 14 year old water heater without a problem
And also replaced the drain valve on our 22 year old boiler
Turn the WH off before you drain it
--maybe the night before
--then take a shower in the am to use the hot water in the tank
Don't turn it back on until its full of water again
Old 06-15-2010, 10:58 AM   #13
Household Handyman
Rewards Points: 1,408
I'm with "nap" as far as changing the drain valve on new water heaters. I do this and the charge to the owner is minimal, but the benefit down the road is worth it. David
Leaking drain valve in hot water heater rhelfand Plumbing 7 12-07-2012 05:37 PM
Tankless Water Heater welshie Plumbing 12 03-03-2010 01:46 PM
Does code require floor drain for water heater? Quickdraw Plumbing 1 05-21-2009 07:29 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
