Water Heater Dip Tube Problem? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2011, 08:17 PM   #1
My 6.5 year-old gas hot water heater (50 gallon A.O. Smith) has started running out of hot water after 15 minutes or so. A plumber told me it was probably a bad dip tube and it would be better to replace the whole hot water heater, rather than repair it.
Does this sound like an accurate diagnosis? What can I do to confirm the problem? And do you really replace rather than repair?
Thanks for any help,
Steve
stevealex is offline   Reply With Quote
Old 04-06-2011, 08:39 PM   #2
Experienced
Jackofall1's Avatar
Hello and welcome aboard Steve, to the best darn DIY'r site on the web.
Replace the dip tub, may as well do the anode while you are at it, the tank is only at its 1/2 life.
Mark
Whirlpool Energy Saver Water Heater Problem Thurman Electrical 47 02-12-2017 08:24 PM
How to flush water heater that has solar panels Homerepairguy Plumbing 2 11-11-2010 08:26 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Water Heater Problem mdong HVAC 19 11-29-2009 10:53 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
