Old 11-25-2006, 12:20 AM   #1
sz8
water heater dilemma
Hi,
I recently found that hot water in my house is running low pressure.
If I turn on two faucets with hot water only, it runs quite slow.
I checked and found that the valve at the inlet (3/4" copper pipe) of the water heater
can not be turned off. It simply keeps turning and never locks
at either direction.
I suspect that the valve does not open completely causing the
problem. I think I have two options:
a) Repair/replace the valve (soldered on).
b) Have the water heater (9 year-old, 50 gallon/natural gas type)
changed with the valve replaced by professionals.
For option a), I am not sure how hard it is. I don't have much
plumbing experience other than installing a under sink water filter
with a compression Tee added. But I am a pretty handy person.
Or if the water heater needs to be replaced anyway, then I don't
need to bother. BTW, the water heater's brand is "American" and
never failed before.
Any suggestions?
Thanks,
SZ
sz8 is offline   Reply With Quote
Old 11-25-2006, 09:12 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Go with option A, replace the valve with a new ball valve.
Ron The Plumber is offline   Reply With Quote
Old 11-27-2006, 02:16 PM   #3
sz8
tricky? From what I know, the procedures should be:
1. turn off the house water.
2. open up one of the hot water faucet.
3. drain the water heater (with a garden hose hooked on).
4. cut off the old valve and solder on a new one.
Is there anything that I need to be really careful ?
One of my concern was that: since I never drained the water heater,
it might not be able to drain. Also, if it drains, it might not be closed
again due to old seal. Is such thing common for a 9-year old water heater?
Thanks,
SZ
Old 11-27-2006, 03:29 PM   #4
Electrical Contractor
If it is electric then turn the breaker off first.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
Old 01-01-2007, 03:24 PM   #5
sz8
Hi,
I've finally done the valve change myself. This is something I
never thought that could be done myself. Thanks to this forum.
Here is the picture. By the way, I did not drain the water heater
before the change.
http://i27.photobucket.com/albums/c200/shanzhu/pipe.jpg
SZ
Old 01-01-2007, 03:35 PM   #6
Journeyman Plumber
Nice Job
Fix it right the first time, so you won't have to fix it a 2nd time.
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
