Water Heater Connections (CPVC) - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2012, 07:33 AM   #16
Shark Bite
Originally Posted by LateralConcepts View Post
Actually that one appears to be a garden hose thread. This is the one you'd need on both sides
http://www.amazon.com/gp/product/B00...TF8&s=hi&psc=1
I'm late to this discussion and I am sure the original installer with a question has finished his installation. I used this fitting and it failed after about 5 years. It began to leak where the CPVC joins the brass. I recommend using a shark bite. It is a great fitting and easy to replace if it fails. It is available at Home Depot.
rmloan is offline   Reply With Quote
Old 01-21-2012, 08:02 AM   #17
Cpvc
I debated replacing leaky copper with copper or CPVC. Subsequently, copper was banned in my town due to an epidemic of pinhole leaks. CPVC is now code for all new construction. I'm glad I went with CPVC. It is much easier to work with and significantly cheaper.
Regarding the configuration question. That will work on an electric water heater. For a gas heater, I recommend galvanized pipe with a couple of turns to create space between the vent pipe and the CPVC. Galvanized pipe>Ball Valve> Shark Bite fitting> CPVC. That space can also be created with the flex pipe recommended by another poster.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Raising Water Heater Tank doesntmatter Plumbing 6 09-30-2010 09:05 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
