-   -   Water Heater Connections (CPVC) (http://www.diychatroom.com/f7/water-heater-connections-cpvc-92566/)
Pittsville 01-17-2011 01:15 AM
1 Attachment(s)
I'm plumbing our house with CPVC and have moved on to the water heater. I'm considering making the following connections (as illustrated by my MSPAINT masterpiece :laughing:).
Attachment 28789
I think I would rather use brass transition unions over the all CPVC versions with the elastomeric seal. Similarly, I feel more comfortable using the brass ball valve vs a CPVC version. All threads would be sealed with Oatey Great White pipe joint compound.
The unions are obviously designed to allow me to disconnect and move the water heater for maintenance. The additional union on the cold side (right below the valve) should allow me to disconnect the line and unscrew the ball valve. That way I won't have to cut the CPVC should I need to replace the valve.
I'm interested in hearing everyone's opinion on this configuration. Comments and suggestions for improvement are always welcome!
michaelcherr 01-18-2011 02:53 PM
I am getting ready to do avery similar install.
I am thinking about something similar, except replacing the piece of cpvc between the shutoff and tank with galvanized.
It just seems like a waste to use a MPT to cpvc transition just to switch back with another cpvc to FPT a foot or so later.
Pittsville 01-19-2011 12:47 AM
You know... I hadn't even thought about using a nipple there. Simple, but efficient. Great idea!
LateralConcepts 01-19-2011 09:06 AM
I'm not a fan of CPVC, but I'd just use 18" flex supply lines connecting to the nipples on the heater. Stub your CPVC down with MIP adapters. On the hot side you'd connect your flex supply directly to the MIP. On the cold side, you'd connect a MIPxFIP ball valve, then your flex supply line. Either way, check your local codes.
JoeLena 01-19-2011 09:24 AM
And I believe you'll need a transition for the hot side, the adapters all say for cold water only, here's a transition I found: http://www.plumbersurplus.com/Prod/G...u=313632363530
LateralConcepts 01-19-2011 09:36 AM
Actually that one appears to be a garden hose thread. This is the one you'd need on both sides
http://www.amazon.com/gp/product/B00...TF8&s=hi&psc=1
JoeLena 01-19-2011 09:39 AM
Doh! That's the one I meant:jester:!
Pittsville 01-19-2011 01:38 PM
Yep, that's the one I'll be using. It's drawn (poorly) at the top of the cold side in my illustration above. With the configuration pictured, I was only using the one. Thank you both!
HVAC_NW 01-19-2011 05:25 PM
That's one complex system. How about you scrap everything in between the water heater and the ball valve and use a 3/4"MIP to 3/4" FIP flex line? (you can get them in 12,15,18 and 24 inch lengths) You can use a stainless braided, or use a BrassCraft polymer line if you feel like you've gotta have that dielectric isolation, which the polymer line provides.
3/4" MIP from hose into ball valve, and 3/4" FIP with gasket seal onto water heater. I agree with using brass or bronze ball valve. I would personally avoid plastic female threads since they can split easily.
I had better luck with pink or yellow, high density PTFE tape than pipe dope. I had a thread I couldn't get it to stop leaking with dope, but sealed right up with the pink tape.
Earnie 01-20-2011 06:47 AM
Are heat traps still a good idea on the HW heater pipes?
Mechanical or simple horse shoe in the pipes?
Pittsville 01-22-2011 11:23 PM
I haven't read/heard anything that would suggest an issue with using heat trap nipples. I'm using the style with the small flapper on the one end of the nipple. (this end installed closest to the water heater) What reason/shortcomings exist in terms of using the heat traps?
HVAC_NW 01-25-2011 02:07 PM
The shortcoming with the older metal ball type is that the make clicking noise whenever there is flow and sometimes, the ball becomes stuck and stops hot water.
I'm not sure, but I think the modern rubber flappers that look like flappers aren't nearly as effective compared to using insulated inverted U pipes on both sides, but I have no idea how much energy you'll save with installing external heat traps.
Earnie 01-26-2011 06:55 AM
Restrictive flow may be an issue. I searched for 1" heat traps but could not find any. There are plenty in 3/4". The U is just pipe so no mechanical components to fail.
Pittsville 01-27-2011 02:37 AM
Never heard is using U shaped pipes in this manner. Can one of you elaborate?
HVAC_NW 01-27-2011 01:43 PM
http://www.energycodes.gov/moodle/mo...iew.php?id=109
Just because of physics that hot water is lighter than cold water, it rises. Without a heat trap, the hot water rises up the pipe, it gets cooled, gets sent back to tank, and circulates like a lava lamp.
The inverted U traps the heat from going past the top of arch. I think its best to do it using 24" flexible pipes. If you use a bunch of 90 degree elbows you'll have turbulent flow that contributes to flow drop.
Also, spend the $20 or so and replace the drain spigot with a brass nipple and a 3/4" ball valve. Do it before you install it or as soon as you can. The most difficult part is probably removing the old plastic drain valve as it will break or twist around as you to remove it.
