Water Heater Confusion - Need Help Pls - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2008, 12:52 PM   #31
I waited a few days to make sure and everything thing is working great, problem solved. Thanks for your help!
spikesnet is offline   Reply With Quote
Old 10-29-2008, 11:14 AM   #32
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Water Heater Repairs
Originally Posted by jamiedolan View Post
Good job! The old element doesn't look that bad to me. I bet that old valve is just a crappy valve and that was likely what caused it to drain slowly.
Give it a couple hours, and if your water is up to the proper temp, then you should be able to assume that your all done.
I bet you saved at least $200 that a plumber would have charged to come out and change that element.
Jamie
YES THAT IS TRUE,
BUT A GOOD PLUMBER WOULD HAVE DONE THE
WHOLE JOB IN JUST A 11/2 HRS START TO FINISH,
BUT IF YOU WANT A SUPER GOOD ELEMENT
GO TO ACE HARDWARE,
AND GET A SANDHOG/LIFELONG ELEMENT
IT'S INCLOY AND LASTS 10 TIMES AS LONG PLUS PUTTING OUT EXTRA HEAT
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Old 10-29-2008, 11:18 AM   #33
Originally Posted by MACPLUMB View Post
YES THAT IS TRUE,
GO TO ACE HARDWARE,
In my defense, this was my first time. Now that I know how to do it I could probably knock it out in a couple of hours if I had to do it again.
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 09:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
