Water Heater Collection Pan Filled With Water. Leak? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2014, 02:31 PM   #1
Rewards Points: 452
water heater collection pan filled with water. leak?
The water heater sits on a collection pan. The pan has a drainage hole, and the pan has collected some water.
I have never noticed water in the pan.
Anyone have any idea what/how I should diagnose?
pman6 is offline   Reply With Quote
Old 02-06-2014, 02:48 PM   #2
Rewards Points: 320
Try looking at the pressure relief valve, see if its leaking. Can you post a pic? Thanks.
jmon is offline   Reply With Quote
Old 02-06-2014, 07:22 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 818
How old is the tank? Gas or elect.?
Check the nipple connections first
If electric, turn the heater off at the panel and remove the element covers to look for water leaks around them.
Those are the obvious places to look. If the tank is pretty old the inner vessel itself maybe shot and time for a new heater.
Old 02-06-2014, 08:07 PM   #4
Rewards Points: 2,040
Cold weather cold water tanks old it leaks... Ever notice the rise in HWT leaks each fall / winter.
Old 02-06-2014, 08:10 PM   #5
If the T and P is blowing off I would suggest you remove the source of heat or electric first then trouble shoot. A T&P leak could be the T&P doing its job... That is preventing a launch through the roof of your house. Or it could just be a bad t&P but better to be safe then sorry.
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 05:00 AM
