Water Heater Cold Water Line Corroded? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-27-2015, 09:56 PM   #1
Rewards Points: 2
Question
Water heater cold water line corroded?
Hi all,
My parents had this water heater installed probably 5ish years ago, and I recently saw it and the cold water line has a lot of buildup/corrosion on it. I attached a picture. The little valve is attached to the furnace humidifier.
Has anyone seen this before? Can't tell if it's all from condensation, small leak, or something else?
Thank you
jon1003 is offline   Reply With Quote
Old 09-27-2015, 10:13 PM   #2
Rewards Points: 318
Looks like a small leak develop from that saddle valve and rusted everything out.
jmon is offline   Reply With Quote
Old 09-27-2015, 10:35 PM   #3
Rewards Points: 318
I would say most of your problem is from that saddle valve. Could be other issues as well. Have to remove that rag and see where it's leaking from. I'm guessing the saddle valve.
Easy fix. If it is the saddle valve, replace it with a sharkbite slip tee and push on appliance valve as noted in link (see link below). Turn off water, relieve pressure, no soldering needed. Then clean that corrosion off with some vinegar and flour before you have to replace all the pipe and fittings. Just a suggestion.
Please wait for the plumbers to respond. Thanks.
Old 09-28-2015, 07:22 AM   #4
Rewards Points: 788
Off topic, and OP may be already aware. Check the humidifier reservoir and make sure there's no bacteria.
carpdad is offline   Reply With Quote
Old 09-28-2015, 09:55 AM   #5
Rewards Points: 318
Depending on your skills, another option would be, if the threads are not all rusted out, is to break it free at the union and replace everything.
If you do not have the skills required to fix it then tell your parents to hire a local plumber to get the leak stopped before any more damage occurs. It's starting to rust out the flue, inlet, and top of water heater. Rags and paper towels is not going to work.
The plumbers will be along shortly to give you more advice/suggestions.
Old 09-28-2015, 10:52 AM   #6
Rewards Points: 318
What's above the saddle valve where the rag is wrapped around. First step is to find out where it's leaking from. Go from there. Looks like leak is coming from above somewhere.
Old 09-28-2015, 05:07 PM   #7
Rewards Points: 2,036
Perhaps that is why saddle valves have been removed for use by the IPC.
Old 09-28-2015, 05:59 PM   #8
Rewards Points: 582
shut off water...cut out pipe above saddle valve...install shut off vave full port flow..install 1/2 cxc tee then connect to dielectric union on top[ of tank...out of tee install 1/2 by 1/4 shut off for humidifier...
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
jmon (09-28-2015), TheEplumber (09-28-2015)
Strange plumbing to my elec water heater > photos Flt_Simulation Plumbing 17 05-13-2014 04:52 PM
Vacuum breaker with tankless water heater? braman Plumbing 3 04-07-2013 01:40 AM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
