Water Heater Closest Smells Like Propane - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-26-2011, 09:20 PM   #1
Water heater closest smells like propane
Like the title says, my water heater closet smells like gas. It's a pretty strong smell once I open the door. I checked the exhaust and it isn't clogged, turned the heater on hotter so it would ignite and I checked out the ignition bar and didn't notice any spots not burning so it appears to be burning efficiently. I've done a soap test before and didn't find any leaks. I'm going to spray again just to double check. I haven't checked anything else and am not sure where to go from here. I've got the door propped open for now so it'll get good air flow. Oh yeah, and I did check out the vents in the door (top and bottom) and they are both free of obstructions.
surfer85 is offline   Reply With Quote
Old 10-27-2011, 02:35 AM   #2
It's always safest to get a professional there when dealing with gas leaks. There may be a defect in the gas valve that can be detected with their equipment.
Ishmael is offline   Reply With Quote
The Following User Says Thank You to Ishmael For This Useful Post:
surfer85 (10-27-2011)
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 03:54 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
Propane hot water heater philmeister Plumbing 3 04-29-2007 08:20 PM
