Old 03-26-2009, 09:13 PM   #1
water heater best choice
Propane vs. Electric
Tank vs. Tank less
Power vent Condensing?
I have hot cold and return lines help me out guys its a new house and its big but theres only 2 of us in it what would you guys use or due its my own personal house and would like to do it cheaply but i want it efficient over the long run
mike
mhoy9 is offline   Reply With Quote
Old 03-26-2009, 09:48 PM   #2
What can I find here?
Winchester's Avatar
If you want to go on the "cheap" side and be the most efficient for your dollar, go with like a 30-40 gal tank with the propane or natural gas. The below link from EERE will help you size up the tank you need.
If you go a little further on the efficiency, you'll also get some tax credits.
EnergyStar
EERE
Winchester is offline   Reply With Quote
Old 03-26-2009, 10:37 PM   #3
HVAC / Plumbing
Tank vs. Tank less
mike
Just my opinion......I would go tank type condensating W.H (if you want efficienty) B-4 I would go tankless.Tankless is going to cost in $1500.00 + range installed .Cheap would be regular tank type..I would check propane vs elec.prices in your area
kenmac is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Best choice for independent hot water heater? wombosi HVAC 5 01-26-2009 10:49 PM
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
Water Heater tsmith Plumbing 10 12-01-2008 07:24 PM
