Old 01-19-2009, 12:34 PM   #1
water heater ball valve leaking
4 years ago I sweated on a ball valve for my water heater shut off.
Today I am doing some maintainence work and the valve starts to leak. the lever is on top and water seems to be coming out of the lever slowly and dripping down.
Not sure if tightening the nut on top has any use? Or the valve needs to be replaced? Why are did it fail so early?
DIYGST is offline   Reply With Quote
Old 01-19-2009, 01:03 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Could be as simple as tightening the nut below the handle. Try that first. Report back if hat fixed it.
Brik is offline   Reply With Quote
Old 01-19-2009, 01:12 PM   #3
hi I tightened the nut on top of the handle a little but it actually made it drip faster.. any other ideas?
Old 01-19-2009, 01:15 PM   #4
Oh I noticed you said below the handle
I am going to remove the handle and see if I can get that skinny nut tightened up a bit.
Old 01-19-2009, 01:24 PM   #5
Handyguy
Brik's Avatar
Yep, BELOW the handle. The one on top just holds on the handle. The one below may do the trick (depending on who made the valve). Its an easy first thing to try.
Old 01-19-2009, 01:28 PM   #6
Hi, I took off the handle (easy) and tightened the nut below it just a little. It seemed to have stopped the leak, the friction of the lever must have loosened this packing nut
Thanks!
Old 01-19-2009, 01:32 PM   #7
Handyguy
Brik's Avatar
Glad it worked for you. I have run into the same thing, even on brand new ones.
-Brian
Leaking Rheem 60 gal Electric Hot Water Heater aklkuno1 Plumbing 3 10-22-2008 11:13 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 09:23 PM
