Water Heater In The Attic - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2012, 07:51 PM   #1
Water heater in the attic
Does a 30" x 30" access panel in addition to a 22" x 54" fold up staircase meet code requirements in Louisiana for a 24" diameter water heater installed in the attic? The 30" x 30" access is within 5' of the water heater.
RobV is offline   Reply With Quote
Old 02-20-2012, 08:35 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
I would think as long as theres enough room to get it through the opening youd be fine.
Id be more concerned about the rafters being big enough to support the weight myself.
Id figure between 7-8lbs per gallon of water plus the weight of the heater itself sitting up there,dont forget a pan under it and a drain line
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (02-20-2012)
Old 02-20-2012, 10:14 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
One thing I can guarantee is :
If you do this, you will not be a happy camper when it comes time to haul it out.
For the record : I'd rather be troubleshooting sewer pumps all day than trying to haul a junk water heater out of an attic.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plummen (02-21-2012)
Old 02-20-2012, 10:20 PM   #4
Rewards Points: 13,750
I've seen whole houses distroyed from a leaking water heater in the attic.
Old 02-21-2012, 07:23 AM   #5
Rewards Points: 1,514
If you got the water heater up there in the first place, it is not more difficult to get it back down.
Putting water tanks in the attic lets gravity help maintain pressure, although another tank up there filled with air is still needed to prevent "negative pressure" that would slow or stop the flow of water being used if there was a simultaneous problem with incoming water pressure.
Old 02-21-2012, 12:57 PM   #6
It is pretty common to have the WH in the attic where I live. With the use of a com-a-long it was not hard to get it in the attic. My question is whether the 30" x30" access panel would satisfy code
Old 02-21-2012, 01:55 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 684
It's been a while since I've opened my gas book, but I know the requirements are there for access size, cat walk, hand railing, work lighting and power receptacle. I would consider all these factors regardless of the type of heater.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-27-2010 11:00 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
I would like to relocate the flue for my gas water heater Git HVAC 12 04-23-2008 09:37 PM
