Water Heater Any One Knows This Part - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By hkstroud
Old 08-20-2016, 11:23 AM   #1
Rewards Points: 8
Water heater any one knows this part
Hello all,
I hope this is the right sub forum for this question.
So i was not getting any hot water and thought the pilot light had blown out and openede the panel on my hot water heater and i see this part lying squat on top of the burner. It was crumbling and there were crubles all on the heater floor too
Its american water heater with the model PVG62 75T75
Thanks for looking
Krivjohn is offline   Reply With Quote
Old 08-20-2016, 11:35 AM   #2
Rough Rooster's Avatar
Rewards Points: 256
Re: Water heater any one knows this part
That is a glass vial air door support that will shatter when firebox overheats.
Most likely your air intake ports clogged enough to reduce air inflow and firebox overheated causing the glass vial to shatter closing off the air door.
Clean the air intake screen and/or filter then obtain a replacement glass vial from manufacturer and install it correctly (to prop open the air doors). You can then relight water heater and hope for best.
Not a good scenario!
Regards,
RR
Rough Rooster is online now   Reply With Quote
Old 08-20-2016, 11:49 AM   #3
hkstroud's Avatar
Rewards Points: 1,722
Hard to tell from photo but looks like part of the spiral heat exchanger to me.
jeffmattero76 likes this.
hkstroud is online now   Reply With Quote
Old 08-20-2016, 01:49 PM   #4
Rewards Points: 8
Hkstroud,
Thank you for replying. I have taken more photos, if it helps. It fell down from the center tube/vent in the middle of the heater. It was lying right on top of the burner. If indeed its the heat exchanger, is it safe to clean up the crumbles and attempt to light the pilot?
Old 08-20-2016, 01:52 PM   #5
Rewards Points: 8
Regards,
RR
Rooster,
Thanks for replying. I took the part out. It looks spirally and looks like corroded metal. Its falling off into peices in my hand. I also see crumbles on the heater floor. It looks like it fell from the center tube /space in the middle of the heater. Please find attached another photo
Thank you
Old 08-20-2016, 01:54 PM   #6
Rewards Points: 8
Another photo. (Sorry it was letting me attach only a single one to reply)
Old 08-20-2016, 02:18 PM   #7
hkstroud's Avatar
Yes, but replace the heat exchanger as soon as you can. Remove flue pipe, then draft air inlet. Lift out old spiral heat exchanger and drop in new one.
Old 08-20-2016, 02:31 PM   #8
Rewards Points: 256
I was answering according to your first photo.
Do clean the air intake ports and/or filter while you are messing with the heater.
Your other photos clearly show the spiral heat ribbon. Not near the catastrophe as a failed air door glass vial.
Have a good one!
RR
Old 08-20-2016, 02:39 PM   #9
hkstroud's Avatar
Amazing how difficult it is to tell what something is from photo when you have no depth perception isn't it.
Old 08-20-2016, 03:20 PM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
If the WH is more than 6- 7 years old, replace it.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 08-21-2016, 08:07 AM   #11
Rewards Points: 14
I never replaced a spiral heat exchanger, but, before deciding on that, make sure you have enough room above the water heater to be able to install it.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 07:03 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 09:48 PM
Tankless hot water heater during winter when water shut off jdabs Plumbing 3 07-10-2012 01:50 AM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 10:12 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 12:35 PM
