Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-30-2010, 06:02 PM   #1
water heater
my question is on my gas hot water heater there is a leaking 1/4 shutoff flexible water line that goes to my humidifier. It leaks when i shut if off in the summertime. can i replace the shutoff valve or internal parts without installing a new shutoff.
Billkee1 is offline   Reply With Quote
Old 11-30-2010, 06:24 PM   #2
Okay, first of all it is a water heater, not a hot water heater.
Second, does the valve not shut the water off and it leaks through the valve or does the valve actually drip water onto the ground? If it will not completely stop the flow you need to replace it. If it drips, try tightening the packing nut which is the nut under the handle on the stem. Good Luck!
broox is offline   Reply With Quote
Old 12-01-2010, 12:31 AM   #3
Picky Plumber
Wow, Broox! Tell us how you really feel!
Is this valve a saddle-type valve.... if so, replace it. Not worth fixing even if you could.
Plumber26 is offline   Reply With Quote
Old 12-01-2010, 08:00 AM   #4
Rewards Points: 1,216
Yo Broox take it easy, ever see construction drawings or drawings of new houses where they show the utility room and the area for the "Hot Water Heater" it has a little circle there with HWH in it or WH.
We all know what the guy meant lets not get so technical.
Replace the valve with a real valve and reducer arrangement.
COLDIRON is offline   Reply With Quote
Old 12-01-2010, 06:10 PM   #5
okay okay, I do not mean any harm, the "hot water heater" term is just a little pet peeve of mine. I am going to turn on my hot air heater and get a drink of water from my wet water dispenser.
Old 12-01-2010, 06:36 PM   #6
Rewards Points: 150
What do you call a boster heater?
braindead is offline   Reply With Quote
Old 12-01-2010, 06:47 PM   #7
I don't know what a "boster heater" is.
Old 12-01-2010, 08:07 PM   #8
HVAC / Plumbing
A booster heater boost the temp. of hot water. It heats hot water
kenmac is offline   Reply With Quote
Old 12-01-2010, 08:38 PM   #9
ohh, he meant a booster heater. I know what that is.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
