Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2010, 09:26 PM   #1
water heater
does the hot water heater overflow drain (the piping extending from the top of the appliance) have to exit the home to the exterior of the home?
1trboyette is offline   Reply With Quote
Old 07-12-2010, 10:39 PM   #2
Just call me Andrew
Rewards Points: 1,020
Are you talking about the pipe protruding from a valve similar to this picture? If so, you do not. Is yours leaking? Under normal circumstances it should not be.
Andrew
secutanudu is offline   Reply With Quote
Old 07-12-2010, 11:27 PM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
You need to check with your local code official. Here in Ohio we dont have to pipe them to the exterior of the home. Where my mom and sister live they are ALL piped out of the home. Personally I think this is ridiculous. If the damn thing starts leaking how are you going to know if its piped outside. Just my opinion
BTW, that is not an overflow drain. That is a temperature and pressure relief valve which is an EXTREMELY important safety device that keeps your water heater from turning into a missile.
JDC is offline   Reply With Quote
Old 07-13-2010, 09:52 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
In Oregon it depends on where it's installed. You can dump them straight onto a garage floor, or anywhere in the house it can dump into a pan, BUT the pan drain has to go to daylight.
Journeyman Plumber
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
