Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2010, 08:25 PM   #1
water heater
does the hot water heater overflow drain (the piping extending from the top of the appliance) have to exit the home to the exterior of the home?
trboyette is offline   Reply With Quote
Old 07-13-2010, 05:52 AM   #2
Depends on local code, most do not require that.
Old 07-13-2010, 07:29 AM   #3
I have lived in 3 States (Ohio, Florida and Arkansas) and only Florida required this.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 07-13-2010, 07:39 AM   #4
Retired Plumbing Cont.
Actually the Florida Code states in section 504.6.1:
"The relief valve shall discharge full size to a safe place of disposal such as the floor, water heater pan, outside the building or an indirect waste receptor."
rockerjockey is offline   Reply With Quote
Old 07-13-2010, 08:34 AM   #5
Long-Time DIYer
Mike Swearingen's Avatar
I have my T&P valve line plumbed to discharge down into a drain pan and IT is drained to under my house in the crawlspace in case there is ever a blowout. If you can get it fairly easily plumbed to the outside, that's they way to go. Otherwise, if it blows inside the house, you are going to have a heck of a scalding flood (although the water heater won't blow up).
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-13-2010, 12:25 PM   #6
When I did house work in Ocala Florida, the Code required the TP discharge pipe to exit the house and go into a french drain, at least 16" deep (we used a piece of 8" PVC filled with stones) and also have a tee with one outlet facing upwards so the owner could see water escaping, and the other outlet piped down into the drain. Guess this was a local Code.
The Following User Says Thank You to majakdragon For This Useful Post:
rockerjockey (07-13-2010)
Old 07-13-2010, 01:09 PM   #7
A good reason to always check with your local bldg. dept.
The inspector always has the last word and it's his interpretation of the code that counts.
Old 07-13-2010, 01:50 PM   #8
Registered User
Rewards Points: 526
Local codes may apply: http://www.codecheck.com/cc/pg19_20mechanical.html
Page #6: http://www.codecheck.com/cc/images/CC5thEdSample.pdf
Be safe, Gary
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
