Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-24-2009, 03:41 PM   #1
Water heater
Trying to check the thermocouple connection for the gas water heater. Trying to get the front plate off the controller. The heads look like a torx head. The smallest I can find is a TX 8 and that is too big. Is this a torx head and if so what size????
rcolmansr60 is offline   Reply With Quote
Old 04-24-2009, 04:40 PM   #2
HVAC / Plumbing
If this is the type with peizo ignitor. If you break the burner seal . You are suppose to replace it. What brand wh is it ? What year.. ?? there were several models that had a recall on them .. Call the 1-800 # on the tank to find out if your's is 1 of the recall models.. They will over night you the parts free.. Does this wh take air from the sides or the bottom.. Some thimes the screens on the bottom or sides where the wh takes air for combustion only need cleaning
kenmac is offline   Reply With Quote
Old 04-24-2009, 06:32 PM   #3
Yes to the ignitor. It is a GE manufactured by Rheem on 05/2006. The air intake is on the sides at the bottom.
It is in a summer place.
When I tried to light the pilot it would light as long as I held the knob down but go out as soon as I released it. The owners guide said to first check the connection of the thermocouple. then if hat was OK to replace the thermocouple. That is why I was trying to get the control box open to check the connection but can not figure out the head on the screws.
Thanks, Dick
Old 04-24-2009, 06:37 PM   #4
HVAC / Plumbing
Call the 800 # . If I'am not mistaken .. This is 1 of the recalled models.. I doubt. Unless you have the proper tools . You won't be able to check t. couple
Old 04-24-2009, 06:46 PM   #5
I'll give them a call. I wasn't planning on checking the thermocouple, just the connection, if that was ok replace it.
Thnaks, Dick
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
Water Heater tsmith Plumbing 10 12-01-2008 07:24 PM
