Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2013, 01:54 AM   #1
Question
Water Heater
When my water heater starts up, it sounds like a small train rumbling into the house. Once it's up and running, it's very quiet. The water heater has 2 straps per code. Any idea why it is so loud when it starts up?
theintruder is offline   Reply With Quote
Old 07-12-2013, 07:05 AM   #2
Rewards Points: 1,300
How old is it? Probably a lot of sediment buildup in the bottom.
danpik is offline   Reply With Quote
Old 07-12-2013, 08:47 AM   #3
Rewards Points: 14,026
At least once a year (more often is better) the built up sediment should have been drained out of the bottom of the heater by attaching a garden hose to the drain and letting it run for a few min.
If it's never been done then the whole bottom of that tank is now loaded with whatever minerals were in your water.
Sometimes it can be broken up with a coat hangers enough so it will drain.
That build up can short out the bottom element is it's electric, or cause the water to take longer to heat up in a gas unit because it acts as insulation.
Old 07-13-2013, 01:17 AM   #4
Thanks Joe/Dan,
Oddly enough, this water heater is less than 1 year old. I replaced the old heater due to the fact that the previous owner never drained the heater. Do you think it's possible that I have the straps on to tight?
Old 07-13-2013, 10:45 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 834
Originally Posted by theintruder View Post
Thanks Joe/Dan,
No,
Give us more info on the heater
gas/electric, brand, model, size, etc.
Old 07-13-2013, 02:51 PM   #6
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
About 2 years ago I replaced a State gas water heater that was installed in 1978, when I later cut the tank open it had a foot thick layer of lyme and it never made any unusual noises or rumbling, in fact it was quieter operating than the new one which has a burner that sounds "turbocharged" when it's lit.
RWolff is offline   Reply With Quote
Old 07-13-2013, 05:50 PM   #7
Heater info
GE ultra low NOx, natural gas...48 gal...9yr
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
