Water Heater. - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2012, 11:52 AM   #1
Water heater.
Water heater shot, can't afford a new one right now. I closed the valve at the top of the heater, but there is a dripping sound and the water heater is still leaking about 15 gallons a day. (I have a hose attached from the drain cock to the bathtub). If I closed the valve, why is it still dripping?
Eric Tide is offline   Reply With Quote
Old 12-17-2012, 12:51 PM   #2
Water is either leaking past that shut-off valve, or is backfeeding (from cold line to hot) through something else such as a tempering/mixing valve.
Ishmael is offline   Reply With Quote
Old 12-17-2012, 02:07 PM   #3
Special User
Rewards Points: 1,230
Yeah, shutoff valves often cake with deposits and leak. You'll need to shut off the main water supply and put a cap on the line supplying the water heater (maybe the hot side too, if a single handle faucet somewhere is backfeeding) as a temporary fix until you can get a new heater and shutoff valve.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-18-2012, 01:21 PM   #4
Thank you.
Old 12-18-2012, 02:24 PM   #5
Roofmaster
Rewards Points: 2,210
Turn off the water, cut the hot out, and cold in and put a sharkbite stop on both. Disconnect the tank and get ready for a new one. Electric or gas?
The reason I ask is that a lot of people get rid of electric that still have a good tank, cause the elements go bad or they have build up in the bottom. Maybe you can get an interim one at the land fill? Just a thought.
Also check out scratch and dent. Dents dont usually matter.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
