Water Heater. - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-25-2012, 08:26 AM   #1
Water heater.
Hi, I need a solution to a problem. I need to be able to have hot water in a shed that has no water feed and is no way near one.
I was hoping there was some way of bringing in water in large drums and then heating this as it passes through a small shower style water heater.
How would I pump this water into the water heater.
Sorry if this is as clear as mud.
CharlieByrne is offline   Reply With Quote
Old 10-26-2012, 10:34 PM   #2
Missouri Bound's Avatar
This can be done. Any chance you can elevate the drums above the water heater? Then you could have a pump to supply the water to the valve(s) and gravity would take care of keeping the heater elements immersed. More details please.
Do you want it your way or the right way?
Old 10-27-2012, 09:31 AM   #3
Rewards Points: 196
Buy a portable on demand water heater used for camping.Ive got a coleman and it is endless hot water.It can be feed with a garden hose or attached to a water container.Mine also has a shower attachment.
HVACTECH96 is offline   Reply With Quote
Old 10-27-2012, 02:38 PM   #4
biggles's Avatar
are you looking to wash your hands in the shed or taking a shower?????
Old 10-28-2012, 04:43 AM   #5
I am looking to sell ice cream from it so I need a wash area for hands and a wash area for utensils etc.
I can put the water up high if needed.
Old 10-28-2012, 04:43 AM   #6
Thanks to all of you for your help so far.
Old 10-28-2012, 09:21 AM   #7
DIY staff
Rewards Points: 7,174
Be sure you use NSF approved containers for the water---food service approved----
Like wise for the container used to transport the water to the building----
Your health department might have a strong opinion about your plans---
Best to ask them first.
COLDIRON (10-29-2012)
Old 10-28-2012, 09:43 AM   #8
Rewards Points: 13,300
Just take a look at the way any camping trailer is plumbed.
Old 10-28-2012, 07:54 PM   #9
If you can elevate the tank you won't need a pump. You may need some device to shut off the power to the elements sometimes before you run out of water. Operating the elements without water will destroy them.
Old 10-28-2012, 08:38 PM   #10
Rewards Points: 582
sounds like you may have a problem getting this to pass health code for dispensing food to the public?????ben sr
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
CharlieByrne (10-29-2012), COLDIRON (10-29-2012)
Old 10-29-2012, 07:43 AM   #11
Rewards Points: 1,216
As previously mentioned you need a demand camper setup, a tank with a demand pump on it that only uses hot water when needed, you have to fill the tank by hose .
By the time you buy all that's required it's easier to set up a small used trailer to sell from. Another problem is the dirty discharge water. You better have a meeting with the all the inspectors, and health DEPT. personnel before going any further.
Many years ago I had a small candy store and wanted to sell water ice
WOW what a hassle I needed a 3 compartment sink with hot water requirements from the Health Department I closed the store due to hassles. Not only the sink problem. All NSF approved.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
Old 10-29-2012, 07:54 AM   #12
DIY staff
I have built a few commercial kitchens----Meeting all the codes can be an expensive challenge,for sure----
Google Carlin Mobile Kitchens----if they are still in business---they made the best----amazing quality--Mike---
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
