Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-27-2012, 09:06 PM   #1
Water heater
Does a o smith promax have a thermo coupling
Joe cicala is offline   Reply With Quote
Old 05-27-2012, 09:12 PM   #2
Rewards Points: 582
which model do you have reg 40 gal or power vented model..picture would help...
Old 05-27-2012, 09:18 PM   #3
Rewards Points: 616
in the pic i found it looks like it and if it has a pilot light it should have thermo coupler
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-27-2012, 09:20 PM   #4
Rewards Points: 582
see post #2 to be sure
The Following User Says Thank You to ben's plumbing For This Useful Post:
jaydevries (05-27-2012)
Old 05-27-2012, 10:26 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
If its the newer style with sealed combustion chamber and spark ignition Id guess its a flame sensor instead of thermo coupling,if its all open in bottem it probably has a thermo coupling
Does it have a wire coming out of it or aq piece of copper?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (05-28-2012)
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
