Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2012, 09:04 AM   #1
water heater
when i turn the gas valve to on the pilot lite goes out
babba is offline   Reply With Quote
Old 03-19-2012, 10:44 AM   #2
Rewards Points: 2,238
You might want to give us a picture/s!
rossfingal
rossfingal is offline   Reply With Quote
Old 03-19-2012, 10:47 AM   #3
Rewards Points: 13,468
Well that makes no since, sounds like your shutting it off instead of on if the pilot goes out. How would it light is there was no gas?
Old 03-19-2012, 12:21 PM   #4
As long as you are sure you're turning it the right way, I would suspect a bad gas valve.
hvac benny is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
