Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2012, 07:58 PM   #1
water heater
why does the gas valve on bradford white high efficiency water heater flash a gas valve default code
alfman is offline   Reply With Quote
Old 03-07-2012, 08:02 PM   #2
Rewards Points: 582
because something is wrong????
Old 03-07-2012, 08:10 PM   #3
thanks
what would be the purpose of the default code could it be low gas pressure?
Old 03-07-2012, 08:15 PM   #4
Rewards Points: 582
there should be a chart on heater showing the different fault codes....look ..to see what code you have...
Old 03-07-2012, 08:17 PM   #5
yes it says gas valve fault
Old 03-07-2012, 08:21 PM   #6
Rewards Points: 582
I would unplug heater for a few moments ..plug back in ...watch operation to see why it is failing.....power vent starts,,ignitor glows,,,pilot.proves,,,burnners come on till water is up to temp...burnners shut off.. normal cycle
Old 03-07-2012, 08:24 PM   #7
i did that power vent came on for ten seconds shut down nothing else comes on blinks gas valve fault code
Old 03-07-2012, 08:27 PM   #8
Rewards Points: 582
did you check roll out safty switch at bottom of tank....did you make sure vent is not obstructed... if these ckeck ok ..looks like bad valve..... picture of power vent would help
Old 03-07-2012, 08:32 PM   #9
thank you very much for your help sir i really do appreciate it
Old 03-07-2012, 08:34 PM   #10
Rewards Points: 582
welcome ..how old is tank if under 6yrs.. valve is under warranty...
Old 03-08-2012, 04:16 AM   #11
An old Tradesmen
Rewards Points: 7,816
ECO may have tripped.
Old 03-08-2012, 09:29 AM   #12
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is it a tankless? Propane? We had this problem with a tankless when a guy was feeding it from a 5 gallon barbecue propane tank, and the regulator failed due to too high of demand through it.
Good luck
Journeyman Plumber
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
