Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2012, 11:09 AM   #1
Retired NYPD
Water heater
Is it ok to to cut into 3/4 pipe going to hwh, both hot and cold, and putting in a tee to run a 1/2 copper to a new sink? The sink is about 15 feet away. Is pex a good product to use instead of copper? Will it be easier?
FrankLa is offline   Reply With Quote
Old 01-28-2012, 11:40 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 676
Yes, you can. Use which ever product you are most comfortable with. Pex requires anchors at every 32", copper is supported every 6ft. Both are excepted materials for potable water
The Following User Says Thank You to TheEplumber For This Useful Post:
FrankLa (01-28-2012)
Old 01-28-2012, 11:44 AM   #3
Rewards Points: 13,712
Sure it's done all the time. How do you plan on hiding this plumbing to the sink? It really should be run through the wall or down through the floor and come up behind the wall at the sink location with shut off valves.
Pex is super easy to work with but the crimping tool is expancive.
Do not use those cheap gray plactic compression connectors, I've had some pop off.
Old 01-28-2012, 11:49 AM   #4
Retired NYPD
It will be behind the wall.
Old 01-28-2012, 12:07 PM   #5
Rewards Points: 582
yes its done all the time....copper is a good choice for a plumber with soldering.... and some homeowners can solder as well...however alot of diy would use pex user freindly.....
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
