Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-05-2011, 06:46 AM   #1
522
water heater
A O Smith GPVH 50 100 water heater fires 3 times then goes to vacation setting
522 is offline   Reply With Quote
Old 05-05-2011, 07:56 AM   #2
BIGRED
Rewards Points: 252
You should call A.O.Smith, but it sounds like the firing temperature may be set to high and after three firings it is going into a safety shutdown so as not to damage the taNK.
Grampa Bud is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
