.Water Heaeter And Dischage Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2011, 04:11 PM   #1
.Water heaeter and dischage pipe
Can the discharge pipe be run upward and then across to an out side wall
rcalldc is offline   Reply With Quote
Old 01-28-2011, 04:19 PM   #2
Experienced
Jackofall1's Avatar
Discharge from what??? Supported, unsupported, plastic, copper, hot, cold
I think you get it, there isn't enough in this post to advise.
Old 01-29-2011, 09:31 AM   #3
I assume you are speking of the relief valve discharge. The simple answer is no, Your relief discharge must be self drainning and as short as possible. I have heard of cases where it was allowed to be done but required a drain hole drilled in the discharge pipe at the lowest possible point closest to the relief valve. You should consult your local building official, because they are the only one that will have the power to allow this.
Work4living is offline   Reply With Quote
