Water Hammer Noise And Sprinkler - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-05-2013, 09:44 PM   #1
Rewards Points: 50
Water hammer noise and sprinkler
Replaced some old galvanized pipe with copper in master bath. Intent is to do the whole house.
Turned the sprinklers on and now 2 of the valves cause a water hammer noise not heard before.
Any thoughts?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is online now   Reply With Quote
Old 03-05-2013, 09:52 PM   #2
Rewards Points: 218
Maybe new copper pipe is reacting with old galvanized pipe and creating higher pressure causing water hammer. Probably a couple water hammer arresters should quiet it down. Just a thought.
jmon is online now   Reply With Quote
Old 03-05-2013, 09:54 PM   #3
Rewards Points: 50
Placement LOCATION?
Old 03-05-2013, 10:00 PM   #4
Rewards Points: 218
do u hear it all the time? Or just when turning on and off?
Old 03-05-2013, 10:04 PM   #5
Rewards Points: 50
ON OFF and only 2 valves located in backyard, which is close to this bathroom.
Old 03-05-2013, 10:06 PM   #6
Rewards Points: 218
DP, this maybe a helpful link for you, check it out when you have time. Talks about water hammer and irrigation systems etc. sorry I meant to post link not copy. Added link.
link here
Old 03-05-2013, 10:23 PM   #7
Roofmaster
Rewards Points: 2,172
Your original post is pretty confusing for a frequent poster. "I replaced pipe in the bathroom and now the sprinklers hammer?"
Pretty Bizzare. Has all the new work had all the air bled off?
Old 03-05-2013, 10:26 PM   #8
Rewards Points: 50
Not exactly what I said, but no only one valve in the shower has yet to be bled. New sink lines hot and cold have been as well as new toilet line. But shower valve has not been bled yet.
Old 03-05-2013, 11:23 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 444
Double check your new work and make sure the pipes are secure and not banging around.
The Following User Says Thank You to TheEplumber For This Useful Post:
digitalplumber (03-06-2013)
Old 04-28-2013, 06:50 PM   #10
Rewards Points: 50
OK so the hammer is still there and now we are getting a serious vibration or flutter when the shower valve is turned from the full on position to a mid mix valve position. All pipes secure.
So I guess I need to add some water hammer devices?
Last edited by digitalplumber; 04-28-2013 at 09:25 PM. Reason: spelling and "all pipes secure"
Old 04-28-2013, 09:23 PM   #11
Rewards Points: 218
"E", assuming DP bled and rechecked all work, is it possible a pressure regulator could be at fault? Rereading the thread, he never had any problem with hammer, vibration or flutter until he replace some galvanize pipe with copper pipe, then turned on his sprinklers. Thanks.
Old 04-28-2013, 09:29 PM   #12
Rewards Points: 50
E, assuming DP bled and rechecked all work, is it possible a pressure regulator could be at fault? Rereading the thread, he never had any problem with hammer, vibration or flutter until he replace some galvanize pipe with copper pipe. Thanks.
A little more history about this:
The shower we replaced had the plumbing on a wall we took out. Moving to another wall placed the piping under a low roof line so 12-18 inch galvanized pipe arrestors were not replaced.
I have been looking online and apparently the ones that are made can be installed in any direction.
I can do this, but also need to know if I cannot get the arrestor right above the valve, what is the farthest I can install it?
Since I also here it when the sprinkler goes on and off, can I get buy with just the cold side?
Old 04-28-2013, 09:36 PM   #13
Rewards Points: 218
Thanks for clearing that up for us DP.
Old 04-28-2013, 09:47 PM   #14
Rewards Points: 218
I would say, try to get arrester as close as possible to the valve.
Maybe. I would install one on both hot and cold.
Let's see what "E" reccommends, he should be on soon. Thanks.
Old 04-29-2013, 12:23 PM   #15
Rewards Points: 744
When we moved into our house, we were delighted to find a section of pipes vibrated extremely loudly, while toilet was filling or sink was running. I replaced the toilet, but the vibration remained. Then, I drained the entire system...hot and cold lines, including the water tank. Filled it all back up, purged air out of the lines, and vibration was gone. I don't have much explanation, but it worked. Could've been bad angle stop valves, they were shot after 20 years, but I didn't touch them at the time.
Seattle2k is offline   Reply With Quote
Sprinkler valves not quite cprao Plumbing 9 04-16-2012 06:02 AM
Anoying sound in house water pipes when sprinklers are ON gante Plumbing 1 06-07-2010 07:04 AM
Noise when turning on water anywhere in the house pkulkarni001 Plumbing 2 04-10-2006 05:20 PM
