Old 05-14-2007, 10:49 AM   #1
Default Water hammer-ish sound in wall.
Greetings all.
I have had a water hammer-ish sound coming from my wall in my townhouse. When the toilets are flushed (with "contents") there is a loud vibration/knock in the upper downstairs wall. It doesn't make the sound if the toilet is flushed with water only. I also tested this with all the water turned off so there was no refilling of the toilet and it still makes the noise.
So I called a plumber out and he rebuilt one of the toilet assemblies which didn't help. He also shut off the main water supply and turned on all the faucets to make sure there wasn't any air trapped in the pipes but that didn't solve the problem. He told me that he'd have to cut part of the wall out to secure the drain pipe and that might solve the problem. I told him I'd get back to him.
So have does anyone have any advice before I start cutting holes in the wall? Is there anything else I should try first? If I do cut holes in the wall, will simply securing the pipe be a real solution, or just half-a55ing it?
Thanks so much for your advice. Sorry for all the questions.
filthee is offline   Reply With Quote
Old 05-14-2007, 01:42 PM   #2
Drain pipe ?? you dont get water hammer from a drain line ! Your water pipes might need to be strap to some backing , there may not be air chambers in the system causing the problem , I've also seen a lose stem washer sound the same way .
tzzzz216 is offline   Reply With Quote
Old 05-14-2007, 02:47 PM   #3
Can you elaborate on the stem washer? I'm not sure what that is.
I went home at lunch to try a few things and here's what I found. The vibration/noise happens when either of the upstairs toilets are flushed. I tried flushing with the refill valve completely open, partially open and completely closed and the sound persists. The noise is a bit softer if the valve is completely closed so the toilet can't refill, but the noise is still there. I also tried holding the 'flapper' open in the tank as it was flushing and it didn't help the noise.
The sound/vibration happens at the moment the 'package' in the toilet makes its way down the pipe to (I'm assuming) an angle in the drain and causes a disturbing rumble. When you hear the toilet bowl 'gulp air' on the flush is when the noise happens. This is why I think it doesn't sound so loud when there isn't a package in the bowl. There is no air pocket being pulled down with the package and that could be causing the rumble.
Anyhow, anyone else have any ideas?
Thanks!
Old 05-14-2007, 03:59 PM   #4
this is so strange... I think you can try different packages to start with... may use some bread, a little bread and then more bread see if it makes any difference....
KUIPORNG is offline   Reply With Quote
Old 05-14-2007, 04:07 PM   #5
Thanks for your help!
I've tried it with varying levels of toilet paper. It won't sound up until (what I consider) a normal amount of toilet paper/other stuff is present.
But when it happens it is loud enough to make you cringe.
Also, I should note it's a short, violent vibration. 1 second at the most usually. It goes like this:
Flush > water rushing downline for 3-5 seconds > BRAPRAPBRRAP > water finishes rushing downline.
Old 05-14-2007, 04:10 PM   #6
Would it be possible your vent from the roof/outside is blocked a bit?.... as I assumme you do not have this problem until recently...
Old 05-14-2007, 04:21 PM   #7
Eh... I can check. Is there an air vent for the drain pipes?
I've been noticing this for a few months. The townhouse is about 5 years old.
Old 05-14-2007, 04:31 PM   #8
Yes all drain pipes has to have vent... there may be one or two or more ... normally found at the roof...
well these are base on the information I read from the plumbing book... I am not a plumber... although I install some plumbing in my basement and there is a 2" vent there...
may be you want to wait for the "Ron the Plumber"'s reply for a more information... He is the expect here...
Old 05-14-2007, 04:51 PM   #9
Thanks KUI****G!
*beeeeep* Paging Ron the Plumber... *beeeeeep*
Old 05-14-2007, 08:46 PM   #10
Journeyman Plumber
Ron The Plumber's Avatar
Water hammer is associated with the water lines, something does not sound right, your talking about the toilet, I can't grasp what could be the problem your having, water lines cause hammer, drains don't.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 05-14-2007, 09:36 PM   #11
Hey Ron. I'm probably misusing the term 'water hammer'. It's really just a loud, short vibration in my downstairs wall/pipes when either upstairs toilet is flushed with something in it. It happens right as the last bit of water/air/package exits the bottom of the toilet bowl and makes the final gulp.
I played around again tonight after work and it did the same whether the shutoff valve was open or closed. Today the plumber installed a new ballcock assembly in one of the terlets and it didn't help either. The only way I can get it to flush without the bang/vibration is to put nothing in the toilet when I flush it.
I read somewhere that possibly my water heater might have some trapped air. But I don't think I should be messing around with that even if it might be a culprit.
Old 05-14-2007, 10:15 PM   #12
Journeyman Plumber
So you are talking about the noise the toilet makes when the bowl water hits the bottom of a flush?
This could be normal operations, have you always noticed this?
Old 05-14-2007, 10:24 PM   #13
Thanks for your help, Ron.
No, sorry. I'm saying the loud pipe vibration in the downstairs wall happens when the bowl upstairs makes its normal, gulping, flushing sound. The sound I hear in the wall downstairs definitely isn't normal and started doing this fairly recently.
Old 05-14-2007, 10:27 PM   #14
Journeyman Plumber
It's really hard to say what is the problem without hearing it myself.
Old 05-14-2007, 10:30 PM   #15
That's what I'm hearing. The plumber told me I should cut a hole in my wall and secure the pipe to a stud. I'd like to explore any other option before coming to that though.
Thank you Ron. You're a gentlemen and a scholar.
More On This Topic
We are going to talk a little bit about the demolition that we had to do to get started with this project. As you can see this wall along here has been exposed. You can see the 2x6 construction. We came in and decided where the new door should be into... Read More »
We've all heard the frantic request from the bathroom to bring the toilet plunger before the toilet runs over. All of us will cope with a toilet malfunction at one time or another. Some repairs are best left to the experts, but many fixes are simple once... Read More »
Ok. Now, we're going to talk about how we ran cold water. Again, our cold water line was already existing here. So, I cut off the old pipe added a ninety. And, we've started running it along the wall here. And, then here we have a "T" that runs up and... Read More »
We are going to talk a little bit about how we are going to get water to our shower, our toilet, our new washing machine, and our sink. What I had to do was I had to find a place where I could pull cold water and also pull hot water and being that these... Read More »
Amidst a drought, most of the country receives little rainwater, if any, these days. When these parched parts of the country do get rained on it is sensible to collect all we can, in order to conserve resources and use it wisely. Follow this article for... Read More »
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 12:28 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 11:47 AM
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 09:36 AM
Water Hammer ffgus Plumbing 3 12-31-2006 12:19 PM
water hammer question seanstoner Plumbing 7 04-10-2006 06:28 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
