Water Hammer Driving Me Crazy - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2012, 10:51 AM   #1
Water hammer driving me crazy
Hi All,
I have been having a water hammer problem for the past couple of weeks. I looked at the videos that tell you to drain the system. I did that and the problem left for about a day and a half. I'm thinking that I will have to install arrestors.
My question is I have a building with 3 separate apartments and a laundry room in the basement. Will I have to install arrestors in all of the apartments and laundry room? Will that be arrestors in both the kitchen and bathroom? This is the thing I am most confused about. So that means 4 per floor (2 in BR & 2 in Kitchen)?
This is where I am the most confused. Please help
fantayja is offline   Reply With Quote
Old 07-14-2012, 11:37 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Do you know what the water pressure is for the building? Perhaps your water supplier has boosted the pressure causing some pipes to start hammering recently. Buy a simple test gauge at a box store and take a reading at a hose bib or laundry box- should be around 60lbs. No more then 80lb.
If excessive, a pressure reducing valve and expansion tank could be installed to lower it and possibly quiet the hammer noise.
You can also put mini arresters at each troublesome fixture rather then the main piping.
The Following User Says Thank You to TheEplumber For This Useful Post:
fantayja (07-14-2012)
Tags
plumbing , water hammer
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
another water hammer question rtoni Plumbing 0 05-18-2011 11:26 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
