Water Hammer After Replacing Shut-off Valves? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-24-2010, 09:58 AM   #1
Water hammer after replacing shut-off valves?
I just got around to replacing two leaky old shut off valves to our 2nd floor shower with 1/4 ball valves, and they seem to work great.. However, somehow it has begun some water hammering issues.. The hot and cold supply split at a tee at the shower and run to the toilet and bathroom sink. While turning the hot or cold off at the sink and/or toilet, I can hear the pipes shuddering fairly loudly. They also seem to knock when turning only the cold supply ON, again at the sink or toilet.. No issues whatsoever with the shower, or the plumbing in the rest of the house, it just seems to have affected everything after the shower. I've looked for air chambers in the wall, can't find anything.. The weird thing is that the problem disappears when the new shower shut offs are closed.. I have spoken with a plumber and he seems confounded and doesn't think the valves could have caused this, but we have never had any issues before this? Anyone have any ideas about this?
gspck is offline   Reply With Quote
Old 11-24-2010, 10:34 AM   #2
SDC
SDC's Avatar
check to be sure all straps (fastening to the studs) are tight. Pipes will move when turned off and on, look at a garden hose while doing the same. Make sure you have placed enough pipe clamps/straps and they are all tight.
David Cookman
www.SDCookman.com / FaceBook
SDC is offline   Reply With Quote
Old 11-24-2010, 10:59 AM   #3
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Do you have air columns or hammer arrestors in place on the pipes? When you removed the old valve you didn't per chance cut off the old air column with it, did you?
hyunelan2 is offline   Reply With Quote
Old 11-24-2010, 11:38 AM   #4
as the previous post mentions adding water hammer arrestors could ease the problem.
if you didn't have the issue before the valve install, i would think the valves are an issue. unless its a typo, 1/4" is really small for any plumbing fixture. Are the pipes 1/4" or did you install a 1/4" ball valve on a 1/2" pipe?
moopey is offline   Reply With Quote
Old 11-24-2010, 12:02 PM   #5
Homerepairguy's Avatar
Rewards Points: 998
I think what he meant is quarter turn ball valves.
Homerepairguy is offline   Reply With Quote
Old 11-24-2010, 12:32 PM   #6
The original valves were the only thing removed.. And yes, I meant to say 1/4 turn ball valves.. On 1/2 copper pipe. Most of the offending plumbing is visible from below at the moment. There is a short section that is obstructed that could, I suppose, contain air chambers.. There are no water hammer arrestors currently. Now I'm thinking of having them added, but it still seems odd to me that any movement of the pipes goes away when the shower shut offs are closed.. Seems like a band-aid fix. As far as I know, there's not much in the way of strapping. Maybe I jostled the pipes a little loose when working on them? Or somehow I affected the water pressure? Beforehand the pipes were SILENT, no knocking or hammering or anything..
Old 11-24-2010, 01:24 PM   #7
Rewards Points: 998
Ball valves are straight through, about full diameter flow. If your old valves were gate valves, the water path was more convoluted. So maybe the flow velocity with the ball valves is just a bit faster now, which is enough to cause your new problems.
As an experiment, maybe try shutting off the ball valves part way and see if the problem goes away.
Old 11-24-2010, 01:42 PM   #8
I have tried shutting the valves partly and the only point at which the hammering stops is the point where the flow is so restricted to the shower that there is barely enough pressure for the water to trickle out.
Old 11-24-2010, 08:55 PM   #9
try turning off the angle stops on the toilets. the diaphragm inside the fill valve can vibrate and make that noise. Also, do you have a prv (pressure reducing valve) if you do tighten the screw/nut on the top a little bit and see if it stops.
the_man is offline   Reply With Quote
Help? Replacing water shut off valves frozenmama Plumbing 4 09-28-2010 06:17 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
Toilet water Supply- Shut off valve kcreds Plumbing 5 04-07-2008 12:44 PM
water hammer question seanstoner Plumbing 7 04-10-2006 04:28 PM
