Old 12-31-2006, 09:46 AM   #1
Water Hammer
We own a 2 story colonial with copper plumbing. When the water faucets are turned off a terrible water hammer occurs. There are water hammer arresters on the hot and cold under the kitchen sink and under the first floor laundry tub. I have drained the entire house water system by shutting off the main valve to the house, and opening up the highest faucet and the lowest faucet. After I "refill" the house plumbing the hammer goes away. But then after a few weeks, the hammer slowly returns. What do I have to do next? It sounds like the whole house is coming undone when the pipes shake.
Gus...
ffgus is offline   Reply With Quote
Old 12-31-2006, 11:04 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Water Hammer
Test the pressure on the house, if the pressure is 80 psi or higher you will need a pressure reducing valve installed on your house.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 12-31-2006, 11:16 AM   #3
Water Hammer
We are on standard city water main, municipal water works, Milwaukee WI
Old 12-31-2006, 11:19 AM   #4
Journeyman Plumber
Water Hammer
Test the pressure, I've seen city water be as high as 110 psi, this could be a cause of water hammer.
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
water hammer question seanstoner Plumbing 7 04-10-2006 05:28 PM
