-   -   Water Hammer (http://www.diychatroom.com/f7/water-hammer-5624/)
ffgus 12-31-2006 08:46 AM
Water Hammer
We own a 2 story colonial with copper plumbing. When the water faucets are turned off a terrible water hammer occurs. There are water hammer arresters on the hot and cold under the kitchen sink and under the first floor laundry tub. I have drained the entire house water system by shutting off the main valve to the house, and opening up the highest faucet and the lowest faucet. After I "refill" the house plumbing the hammer goes away. But then after a few weeks, the hammer slowly returns. What do I have to do next? It sounds like the whole house is coming undone when the pipes shake.
Gus...
Ron The Plumber 12-31-2006 10:04 AM
Test the pressure on the house, if the pressure is 80 psi or higher you will need a pressure reducing valve installed on your house.
ffgus 12-31-2006 10:16 AM
We are on standard city water main, municipal water works, Milwaukee WI
Ron The Plumber 12-31-2006 10:19 AM
Test the pressure, I've seen city water be as high as 110 psi, this could be a cause of water hammer.
