Water Hammer - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2013, 09:15 AM   #1
Rewards Points: 240
water hammer
is it still ok to use a caped pipe as an arrester ? our current setup doesn't even have one, and doesn't knock. i will be extending this line to the new sink area.
also. is one need one both lines ? i seen a google pic that had only 1. i think it was the cold side, but idk.
Fix'n it is offline   Reply With Quote
Old 10-31-2013, 09:47 AM   #2
Rewards Points: 14,306
Why would you add one if there's no issues?
If your going to make your own a simple tee and a piece of 6" pipe facing vertical and a soldered cap will work.
Here's a few other options.
http://www.bing.com/images/search?q=...stor&FORM=IGRE
Old 10-31-2013, 10:05 AM   #3
Rewards Points: 240
i am removing the old, and extending the line to the new.
it would be a lot easier to head off a problem, than fix it later.
i know i can buy them. but if i can make them and they work well just the same. i would rather keep the cash in my pocket. know what i'm sayin.
Old 10-31-2013, 11:54 AM   #4
dannyoung85's Avatar
The air chambers that you make will eventually get water logged and will stop working. Install hammer arresters on both lines. However, you will mostly notice a difference at a fast acting solenoid valve such as a washing machine or an ice maker.
dannyoung85 is offline   Reply With Quote
Old 10-31-2013, 06:13 PM   #5
Rewards Points: 2,108
Home made hammer arrestors no longer meet code and make you have to drain down the entire waterline every time they fill with water. Personally I prefer using the correct one and not messing with my plumbing when I can be doing things I enjoy doing.
Old 11-03-2013, 08:35 AM   #6
Rewards Points: 240
i bought and installed 2 of them, $25. on to the next project
Old 11-03-2013, 06:05 PM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 996
How long before we start running across failed arrestors? came across one not long ago, they do go bad and they will need replacing at some point. mechanical arresters can not be installed in a non accessible location.. have you seen this in any local codes ?
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 11-03-2013, 06:28 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Strap your plumbing down and you shouldnt have a problem,If it does develop fix the problem instead of just using a band aid.
Like has been said previously check the last valve/faucet you use when it happens.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 11-03-2013, 06:53 PM   #9
Recently here in Missouri they have begun to let plumbers install mechanical hammer arresters in job accessible locations. I have yet to have one fail and need replaced.
Old 11-03-2013, 07:54 PM   #10
IPC only requires them on quick closing valves. So in a house normally only a clothes washer gets them.
Old 11-04-2013, 03:16 PM   #11
Rewards Points: 209
I have personally seen dozens if not hundreds of copper extensions with caps used for this purpose. Apparently the wise ways of the ancients are no longer code.....?? Kinda makes you think that you could put a schrader on them to pump into them if they are saturated. I might just try that in my neck of the woods deep in the Codeless Wastelands.
ChantryOntario is offline   Reply With Quote
The Following User Says Thank You to ChantryOntario For This Useful Post:
plummen (11-04-2013)
Old 11-05-2013, 06:09 PM   #12
What can I say. Perhaps the manufactures of hammer arrestors greased someones palm that writes plumbing code?
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Water hammer, expansion tank? bluefoxicy Plumbing 1 12-12-2012 05:48 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
