Water Hammer - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-24-2012, 08:59 AM   #1
Water Hammer
As I begin to replace the shower valve and plumbing leading to it, I am wondering if I need to replace the water hammer as well? From what I have gathered, water hammers are used when there is an abrupt stop in water flow, such as the end of a line? My pipes don't rattle currently, but that could be because the hammer is in place!
dukes32 is offline   Reply With Quote
Old 12-24-2012, 03:35 PM   #2
Rewards Points: 13,446
Better to have them in place and not need them then to take them out and find out later you needed them.
Old 12-24-2012, 06:30 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 994
I like them in, new code says you don't need them unless on a mechanical valve ( dishwasher ice maker etc,) i still use the old bullets on each bath group never hurts. keep them do not replace with the new mechanical type. looks like you may have had a three or two handle set up which sat lower than the single you have. the hammers should be above the servicing valve and should drain empty when turning the water off in the system. also do something with that galvanize. piping.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-24-2012, 09:52 PM   #4
Thanks, I am going to remove as much of the galvanized as possible and replace with pex. Space is very limited, so I cannot replace all of it, but the shower, toilet, and sink supply lines will be replaced
Old 12-25-2012, 12:45 PM   #5
Rewards Points: 1,492
Non-mechanical water hammer arrestors eventually fill with water and lose their effectiveness. This is because the air cushion is gradually absorbed by the water. If you drain the plumbing system completely (turn the hot water tank off first, although you don't have to drain that tank completely too) the arrestors will empty out also. Twice a year should be sufficient.
Leave the water hammer arrestors in place. You can make a new arrestor out of either PVC or metal if you need to replace the pipe section containing one. It's simply a seemingly useless upward pointing stub pipe.
AllanJ is online now   Reply With Quote
Water hammer, expansion tank? bluefoxicy Plumbing 1 12-12-2012 05:48 PM
big time water hammer Steelhead Plumbing 2 10-22-2009 08:34 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
