Old 08-19-2012, 08:53 AM   #1
water hammer
The hot water in my shower had started to stink. So, I took my hot water heater apart and installed a new anode rod and heating element. There was about 5 inches of calcium build up in the bottom. I cleaned all that out. The water smells fine now, but I have a water hammer problem. Sometimes when I'm sitting next to the water heater I can hear; glub, glub, glub. It sounds like water is draining out and air is coming in. Any body got any ideas?
Tony Bryant is offline   Reply With Quote
Old 08-19-2012, 11:18 AM   #2
JOATMON
ddawg16's Avatar
water hammer
That is not water hammer.....water hammer is where you have water moving fast through the pipes and then the valve that was open, quickly closes....the moving volume of water then hammers the point where it stops...if all your pipes are secured properly, you usually don't hear it....if you have a loose pipe....it will bounce around.
I'm going to guess that you might have some air in your water heater....though I'm not sure how it could get trapped in there. Are your globe valves to the heater fully open?
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 08-19-2012, 01:23 PM   #3
water hammer
OK. The truth is the commode is the only thing that makes a loud pop when I flush it. The sink and the shower just have air bubbles. I bleed them, but the bubbles seem to come back the next day. I don't know what globe valves are but I'll ck into that. Thanks for your reply.
P.S. I'm a roofing contractor and don't know much about plumbing.
Old 08-19-2012, 01:57 PM   #4
JOATMON
ddawg16's Avatar
water hammer
I didn't know much about plumbing until I jumped into it......that is why we ask questions......
A globe valve is that multi-turn shut off valve.....I hate them....they only seem to seal the first time....after that, they never seem to completely close....I prefer ball valves.....
I think you need to go into more detail on your symptoms so the experts here can chime in....
My
and
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
big time water hammer Steelhead Plumbing 2 10-22-2009 09:34 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
