Old 08-11-2012, 01:53 PM   #1
Water hammer
Have a water hammer issue, mainly when the master bath toilet is flushed. The main area of the noise is in the master shower wall. The picture is of the arresters on the washing machine but I am unsure how to change them. Are they soldered on? Where can I get replacements, home improvement centers do not have this type that I can find. Thanks
NavySeniorChief is offline   Reply With Quote
Old 08-11-2012, 03:24 PM   #2
Water hammer
don't jump the gun,,,,,take tank lid off toilet and flush it..as it fills up watch the fill valve and water as it gos to shut off..see if its hammering in there and shaking the water.... it could be fill valve going bad...
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
sdsester (08-11-2012), VIPlumber (08-11-2012)
Old 08-11-2012, 05:31 PM   #3
Water hammer
The water hammer isnt just when the toilet is flushed, just worse. I can shut off the shower valve quickly and hear the hammer. Not sure if that matters but I think it is something other than the valve in the toilet but I will definitely check that first. Thanks
Old 08-12-2012, 01:33 PM   #4
Water hammer
Ben,
I did as you suggested and did not see any signs of the toilet valve causing the leak. Do those arresters just unscrew from the valve?
Old 08-12-2012, 02:09 PM   #5
Water hammer
Ben,
I believe they do ..they are not rechargable...I really don't think that is your problem that little o5 arestor is for washer only because washer valve closes fast...
Old 08-12-2012, 02:25 PM   #6
Water hammer
sounds like someone either didn't strap the piping good enough or if you have a pressure regulator on the main coming in it will act as a check valve. adding an additional shock arrestor may help.
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
big time water hammer Steelhead Plumbing 2 10-22-2009 09:34 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
